I recently migrated to kmotion CNC from mach 3 and have successfully run a few programs. This is on a simple 3 axis mill with steppers currently open loop. I like kmotion much better than mach and it certainly seems to run faster. I also much prefer creating kmotion code in c rather than the mach macro scripting.
I do have a few questions:
First, the jog icons in kmotion seem to work intermittently. I have to re launch kmotion to get them working again. When I say not working I mean nothing is happening. The axis's don't appear to be disabled as I can still manually enter gcodes and make them all move. And re initializing kflop doesn't help. I am using pretty much the same init program that I was using with mach3.
Second, What post processor should I use and are there any critical settings other than the IJ mode. I am using HSMworks and meshcam, the mach3 post seems to work ok.
The emc post prints a G91.1 which kmotion doesn't like, though its easy to remove.
Will kmotion always do strait line rapids?
Is there a safe z equivalent in kmotion or does this need to be done using a user program?
And finally, will kmotion work with any of those mach3 usb pendants that are all over ebay?
I realize it would be less than ideal to control from the computer vs directly sending signals to the kflop.
How about run of the mill USB joysticks, as opposed to gamepads?
Colin
